Creating rectangles
The Rectangle tool has multiple creation modes, and the Push/Pull mode is available in 3D views for instantly extruding the rectangle after creation.
Mode |
Description |
Corner to Corner
Defines the rectangle by clicking two diagonal points |
Center to Corner
Defines the rectangle by the distance from the center to one corner |
Midpoint to Corner
Defines the rectangle by the distance from the midpoint of one side to an opposite corner |
Three Point Rotated
Creates a rectangle that is rotated by a specified angle |
Push/Pull (3D views only)
Instantly extrudes the rectangle after creation; see Push/Pull mode of planar tools |
Push/Pull Combine (available with Push/Pull mode)
When the shape to be extruded is drawn on the face of a solid object, combines the two objects into a single solid addition or solid subtraction; when this submode is disabled, the new extrude remains a separate object, and the existing solid object remains unchanged |
To create a square (1:1 rectangle), press and hold the Shift key while drawing. To create a rectangle with golden ratio proportions (approximately 1:1.618), press and hold Ctrl+Shift (Windows) or Cmd+Shift (Mac) while drawing.
The Ratio field in the Object Info palette displays square, golden, or the ratio of the sides of an unconstrained rectangle.
Creating a rectangle corner to corner
Mode |
Tool |
Tool set |
Shortcut |
Corner to Corner
Rectangle
Basic |
4 |
To create a rectangle from corner to corner:
Click the tool and mode.
Click to set the start point; this point becomes one corner of the rectangle. Move the cursor until the desired size is previewed.
Click to set the corner diagonally opposite to the first corner.
Creating a rectangle center to corner
Mode |
Tool |
Tool set |
Shortcut |
Center to Corner
Rectangle
Basic |
4 |
To create a rectangle from center to corner:
Click at the rectangle’s start point; this point becomes the center of the rectangle. Move the cursor to a corner until the desired size is previewed.
Click to set a corner point on the rectangle.
Creating a rectangle midpoint to corner
Mode |
Tool |
Tool set |
Shortcut |
Midpoint to Corner
Rectangle
Basic |
4 |
To create a rectangle from midpoint to corner:
Click at the rectangle’s start point; this point becomes the center of one of the rectangle’s sides. Move the cursor to an opposite corner until the desired size is previewed.
Press the Alt key (Windows) or Option key (Mac) to orient the rectangle vertically.
Creating a rotated rectangle
Mode |
Tool |
Tool set |
Shortcut |
Three Point Rotated
Rectangle
Basic |
4 |
To create a three point rotated rectangle:
Click to set the start of the rectangle. Move the cursor to set the angle of rotation.
Click to set the rotation angle. Move the cursor until the desired size is previewed.
Click to create the rectangle; the bounding box position indicator in the Object Info palette matches the rotation of the rectangle. (If multiple rotated rectangles are selected, the box position indicator matches the rotation of one rectangle.)
