Architect or LandmarkHardscape properties
Many of the parameters on the Object Info palette are identical to those used to create the hardscape object (see Creating hardscape objects). Only the parameters that are different are described here.
Parameter
Description
Shape Tab
Style
Replace, remove, or edit the current style, or create a new plug-in object style for this object; see Changing plug-in object styles from the Object Info palette.
Editing a style changes all instances in the file that use the style.
Hide style parameters
Hides the parameters that are set by style; these cannot be edited from the dialog box or Object Info palette
Hardscape Settings
Click to edit the selected hardscape object. Only one hardscape can be selected at a time when editing its settings.
To modify the default hardscape object settings, click Preferences on the Tool bar.
General
Hardscape Name
Provide a name for the hardscape, for use in tags and reports
Path Width
Enter the width of the pathway hardscape object
Path Offset
Sets the offset of the pathway centerline from the placement line
Joint I/J Scale
Specifies the size of the joint pattern units, for flagstone, pavers-grid, and pavers-running joint patterns
Joint Pattern Angle
Specifies the rotation angle of the joint pattern
Border Pattern Size
Sets the width of the spaced joints, when spaced joints are selected for the border
Border Pattern Angle
Enter the angle of the pattern inside the border
Draw 3D
3D Type
Changes the 3D hardscape type; see Creating hardscape objects.
A slab with a pathway configuration cannot be changed to a slab drainage type.
Main Area Components/ Border Components
For an unstyled main area slab, opens the Hardscape Main Area Components or Hardscape Border Components dialog box to specify the hardscape components; see Creating hardscapes
Border Components
For an unstyled border slab, opens the Slab Components dialog box to specify the components; see Creating slab components
Drainage Settings
For a slab drainage hardscape, opens the Slab Drainage Settings dialog box; see Slab drainage settings.
Site Modifier
Use site modifier
Uses the hardscape as a site model modifier
Simplification Tolerance
Enter a positive value to redefine the horizontal distance between the closest parts of two neighboring portions of the modifier. A longer distance simplifies the modifier polygon, reducing the number of source points that modify the site model. A shorter distance increases the number of source points that modify the site model. A value of 0 (zero) does not simplify the modifier.
Modifier Vertex Count
Displays the number of vertices created by the hardscape to modify the site model
Update Site Model
Updates the site model with any site model modifications that have occurred.
If the update causes the site model contours to fall outside the minimum/maximum elevation range specified in the site model settings, an alert displays, allowing the range to be adjusted.
Configuration
Indicates the type of hardscape modifier. The selection made here changes the parameters available from the Object Info palette.
Planar Pad: A 3D polygon defines the shape of an element which is added to, and normally modifies, the site model. The site model is made planar beneath the hardscape, similar to a planar pad modifier; see Creating a planar pad or pad with retaining edge.
Aligned: Defines a surface based on surrounding surfaces and modifiers, matching their elevation.
Path: Creates a surface defined by one longitudinal profile and a set of transverse profiles, with the path defined as a polyline
Texture Bed: Creates a texture bed out of the hardscape modifier, similar to the texture bed modifier; see Creating a texture bed
Vertical sides for inner modifiers
Determines whether inner modifiers, such as a hardscape within grade limits, create a transitional surface (when disabled) or a vertical retaining edge (when enabled)
Vertical sides for inner modifiers deselected (on the left) and selected (on the right)
 Pad
(Planar Pad configuration)
Elevation
Sets the elevation of the hardscape
Slope Definition
Select the method of defining the slope, or select None for a flat pad. After selecting the method, specify the Slope, the Elevation at End of the slope, or the Contour Angle, and the other values are automatically calculated and displayed.
Aligned
(Aligned configuration)
Uses the hardscape as a non-planar slab that automatically matches relative elevations along horizontally collinear edges of adjacent roadways, hardscapes, massing models, extrudes, 3D polygons, landscape areas, walls, and pad/pad with retaining edge site modifiers
Realign
Resets the surface alignment with surrounding geometry
Align with Objects on
Selects the objects to align to, based on the layer location of the objects. This offers flexible control over the alignment.
All Layers: Aligns the hardscape with geometry from any layer in the file
Visible Layers only: Aligns the hardscape with modifiers from visible layers only; geometry on invisible layers does not affect the hardscape
Same Layer as Modifier: Aligns the hardscape with geometry that exists only on the same layer
Select Layers: Opens the Select Layers dialog box, to choose which layers with geometry can affect the hardscapt alignment. Click in the Use column to select a layer. To create a new design layer, click New Layer; specify the name for the new layer, and click OK.
Custom Set of Layers:  Opens the Select Layers dialog box, to select or to modify the selected layers.
Interpolate surface
Increases the level of detail of the surface created by the profiles and modifiers
Smoothness Sampling
Enter the sampling rate (0 – 100); higher values add vertices and increase the smoothness
Elevation
 Specifies the modifier elevation (does not apply to the aligned edges)
Modifies the surface of the hardscape with profile lines; see Editing aligned hardscapes or modifiers with profile lines
Profile
Scrolls through the profiles, highlighting the selected one; click the center button to highlight the current profile
Name
Displays the name of the currently selected profile
Profile Line Class
Select <Hardscape Class> to place the profile in the same class as the hardscape; select a class, or create a new class, to control profile line appearance and visibility.
Show profile lines
Toggles the display of all profile line parameters (name, slope, elevation, and markers)
Show profile names
Toggles the display of all profile names
Show slopes
Toggles the display of all slope values
Show vertex elevation
Toggles the display of all vertex elevations
Show profile line markers
Toggles the display of all profile markers
Add Profile
Adds a profile line to the hardscape for modifying the surface
Edit Profile
Enters editing mode for the selected profile, for Editing aligned hardscapes or modifiers with profile lines
Reverse Direction
Reverses the direction of the profile line section
Profile Line Marker Styles
Opens the Set Marker Style dialog box, to select the profile marker type at each end of the profile line; markers can be the same (Match Beginning) or different (Differentiate) at each end of the section line
Delete Profile
Deletes the selected profile
Surface Modifiers
Modifies the surface of the hardscape with stake and grade objects
Show stake objects
After modifying the hardscape with stake objects, displays the stake objects
Show grade objects
After modifying the hardscape with grade objects, displays the grade objects
Edit Surface Modifiers
Edits the surface modifiers; see Editing aligned hardscapes or modifiers with surface modifiers
Longitudinal Profile
(Path configuration)
Edit Profile
Start Elevation/End Elevation
Enter the starting and ending elevation of the modifier; alternatively, enter one of the elevations and ender a Slope value to automatically calculate the other elevation
Slope
Enter the slope value; alternatively, when the Start Elevation and End Elevation are entered, the slope displays
Realign Elevations
If changes occurred to an elevation, resets the affected vertex elevations
Send to Surface
Sends the profile line to the surface of the site model
Profile Line Class
Profile Text Class
Select <Hardscape Class> to place the profile or its label text in the same class as the hardscape; select a class, or create a new class, to control profile line appearance and visibility.
Elevation Marker
Select the elevation indicator type
Elevation Marker Factor
Specifies the scale factor of the elevation marker
Slopes Grade Def
Determines the how the Slope is calculated and displayed
Show profile line
Shows profile lines when profiles are added to edit the aligned slab (see Editing aligned hardscapes or modifiers with profile lines)
Show slopes
Arrow indicates downward
When Show slopes is selected, adds an arrow to indicate which side slopes down
Toggles the display of markers at the ends of the profile line
Opens the Set Marker Styles dialog box, to select the profile marker type at each end of the profile line; markers can be the same (Match Beginning) or different (Differentiate) at each end of the section line
Transverse Profiles
Profile
Name
Profile Line Class
Profile Text Class
Slopes Grade Def
Show profile lines
Show profile names
Show slopes
Add Profile
Adds a profile line for modifying the surface
Edit Profile
Delete Profile
Texture Bed
(Texture Bed configuration)
Texture from Class
Select <Hardscape Class> to use the texture specified for the hardscape class; select a class, or create a new class, to control texture bed appearance and visibility. The indicated class should have a texture applied on the Textures pane, with Use at Creation selected. See Concept: Applying textures by class.
Information
Main Area
Displays the size of the main area
Border Area
Displays the size of the border area
Footprint Area
Displays the area of the entire footprint of the hardscape
Main Perimeter
Displays the perimeter measurement of the main area polyline
Border Perimeter
Displays the perimeter of the border only
Footprint Perimeter
Displays the perimeter measurement of the entire footprint polyline
Site Modifier Information
Update Calculations
Updates the area and volume calculations displayed in the Object Info palette for the area of the site model located under the hardscape modifier (grade limits must exist around the pad)
Site model area and volume data
Displays the area and volume information for the site model area located under the site modifier; select the units for the area and volume (grade limits must exist around the pad). For more information, see Site model properties.
Vertex parameters
Edits the vertices of the path object that the hardscape is based upon; see Editing vertex-based objects
Render Tab
Texture
You can apply and manage textures for Slab and Slab Drainage type hardscapes on the Object Info palette Render tab. See Managing object textures from the Object Info palette and Textures on objects with components.
To set individual border segments to invisible for boundary hardscapes or cut-out holes, select the hardscape object, and then click the Reshape tool. Click Hide or Show Edges mode. Click the midpoint of the hardscape border segments or the cut-out hole to hide. Repeat this process to set the border segments back to visible, if necessary.
To quickly determine the left and right side of a pathway hardscape object, select the hardscape object and click the middle button next to the Vertex field on the Shape tab of the Object Info palette; when the button is clicked, the first vertex of the hardscape object is highlighted with a red box.
When classing the subcomponents of the hardscape object, such as for the joints or tags, the class visibility of the specified class controls the visibility of the corresponding subcomponent. The class attributes are only applied to the corresponding subcomponent when the Use at Creation option is selected for the class. For example, if the Joint Class is set to the Hardscape - Component - Main Joint class, and that class specifies a hatch Fill Style, edit the class and select the Use at Creation option to apply the fill attribute. See Setting class attributes.
A hardscape object can be used as the basis of a retaining wall. This provides the ability to sculpt the site model around the hardscape. See Creating retaining walls.
Editing hardscape objects
Reshaping a hardscape object
Converting a hardscape object to different configuration
Aligning hardscapes or modifiers with existing geometry
Workflow: Creating a section view of a hardscape
Hardscape tag appearance
Specifying hardscape joint patterns
Editing hardscape fills and joint patterns
Creating hardscapes
