Design SuiteCreating a simple stair
Tool
Tool set
Simple Stair
Building Shell
This Simple Stair tool, in the Landmark and Spotlight workspaces (and can be added to the Architect workspace), adds a basic stair object to the drawing. Vectorworks Architect and Landmark products contain a more advanced Stair tool for designs that require complex, detailed stairs (see Creating a stair).
To insert a simple stair:
Click the tool.
Click to place the object in the drawing, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens; set the default parameters. The parameters can be edited later from the Object Info palette.
Parameter
Description
Style
Select the stair style: standard, indented, open riser, or masonry
Width
Specifies the width of the staircase
Flr-Flr Height
Specifies the height of the staircase from floor to floor
Max Riser
Indicates the horizontal maximum thickness of the riser
Tread Depth/Height
Sets the tread depth (front to back) and the tread height
Nosing Depth
Specifies the nosing depth
Config
Select the stair configuration: straight, straight with a landing, left and right landings, and left and right double-back stairs with landings (even and irregular)
Landing Tread
Indicates how many steps occur before the landing (does not apply to even double back stairs)
Separation
For double back style stairs, sets the separation distance between the flights
Offset 1/2
For stairs with landings, indicates the distance to offset the landing from the stairs on each side of the landing
Curved Landing
Creates curved landings; the radius matches the stair width
Stringer Width/Offset
Sets the stringer width (thickness) on each side of the stair, and specifies the distance between the outside of the stair tread to the outside of the stringers
Draw Lower Stair Break
Hides a portion of the stair with a stair break, so that the lower portion of the stair can be displayed in 2D
Show Data
Displays the number of risers and riser height along with the path-of-travel arrow; an Up or Down arrow must be selected in Arrows for stair data to be displayed
Draw Top Tread
Specify whether the stair should include a tread at the same level as the upper floor it serves
Create 3D
Creates a 3D version of the stair to display in views other than Top/Plan
Left/Right Rail
Adds handrails to the left and right of the staircase
Rail Height/Width
Sets the height and width for the railings
Arrows
Select whether to display the path-of-travel arrow, and in which direction
Step/Rail/Stringer Finish
Select the Class to assign to the steps, railings, and stringers
