ArchitectInserting ramps
Tool
Tool set
Ramp
Building Shell
To insert a ramp:
Click the tool.
Do one of the following:
Click Active Def on the Tool bar to select a resource from the Resource Selector.
Click Preferences to open the object properties dialog box and specify the tool’s default parameters.
The parameters can be edited later from the Object Info palette.
Parameter
Description
Style
Replace, remove, or edit the current style, or create a new plug-in object style for this object.
Editing a style changes all instances in the file that use the style.
Hide Style Parameters
Hides the parameters that are set by style; these cannot be edited from the dialog box or Object Info palette
Type
Select a either a standard (simple board) or masonry ramp type
Width
Set the ramp’s width
Height
Set the ramp’s height
Rise over Run
Set the ramp’s rise over run value.
The rise is the distance along the Y axis the ramp rises above the Z height, and run is the distance along the X axis for the ramp to reach that height. This value can be entered as a fraction, and the program will convert it to a decimal.
Thickness
For a standard type ramp, set the ramp’s thickness
Config
Select the ramp’s configuration from the list of preformatted options
Landing Height
Set the landing’s height above the finished floor, if applicable
Offset 1
For ramps with a landing, set a distance, if applicable, to offset the bottom of the upper ramp away from the top of the lower ramp
Offset 2
For ramps with a landing, set a distance, if applicable, to offset the bottom of the upper ramp toward the top of the ramp
Curved landing
Makes the landing curved
2D Stair Break
Creates a break line in the 2D view
Create 3D
Creates a 3D view
Left Rail
Provides a handrail on the left side (facing the top of the ramp)
Right Rail
Provides a handrail on the right side (facing the top of the ramp)
Rail H
Set the handrail height above the ramp surface
Rail W
Set the handrail width
Arrows (2D view)
For 2D views, select whether to provide an arrow pointing up or down, or no arrow
Click on the drawing to place the object, and click again to set the rotation.
Optionally, create a style resource from the object (see Standard plug-in object styles without catalog options).
Workflow: Creating curved ramps
Inserting a stage ramp
