Design SuiteSaving a stair as a symbol
The stair configuration, along with all its parameters, can be saved as a symbol for use again in the current file or in a library file. The stair is saved as a red symbol and becomes a plug-in object with pre-set parameters when inserted. See Concept: Vectorworks symbols.
To save the stair as a symbol:
From the Stair Settings dialog box, click Save as Symbol.
The Save Stair dialog box opens.
Parameter
Description
Destination
Select whether to save the stair symbol in the current file or in a library file available in the user folder
Save as symbol in current document
Saves the stair as a symbol in the current file
Save as template in library file
Saves the stair symbol to a custom default library file located in the user folder; the exact location is displayed upon saving
Name
Enter a name for the symbol
Symbol Folder
Select the symbol folder from the available hierarchy in the current file; subfolder lists are displayed for the selected folder
Symbol folder list
Displays available subfolders for the selected symbol folder; select a location for saving the new stair symbol
New Folder
Creates a new symbol folder in the current file; provide a folder name
Browse
Browses the subfolder contents of the currently selected symbol folder
Select whether to save the stair symbol in the current file or in a library file.
To save the symbol in a library file, select Save as template in library file and enter a name for the symbol. It will be available from the General tab’s Symbol Selection list and the User Libraries section of the Resource Manager. Library files can be shared among users.
To save the symbol in the current file, select Save as symbol in current document, enter a name for the symbol, and select a symbol folder destination for the symbol by double-clicking on the selected symbol folder name. It will be available from the General tab’s Symbol Selection list and the Resource Manager under the Open Files category. Symbols can be shared by exporting them from the Resource Manager (see Exporting resources).
Using saved sets for stair settings
Setting minimum and maximum values for stair geometry
Transferring stair properties
Creating a stair
