 Detail callout instances
  Detail callout instances associated with a detail viewport can be added to or deleted from design layers or viewport annotations. In addition, the Detail Callout Instances dialog box provides an easy way to navigate from a detail viewport to its associated detail callouts.
To edit detail callout instances or navigate to a detail callout:
Select the detail viewport whose detail callout you want to navigate to or edit.
Click Detail Callout Instances from the Object Info palette.
The Detail Callout Instances dialog box opens.
| Parameter | Description |
| Viewport | Displays the name of the selected detail viewport |
| Design Layers tab/Viewports tab | Displays the names of all design layers in the file (Design Layers tab) and all other sheet layer and section viewports in the file (Viewports tab). Each item that contains a detail callout associated with the selected detail viewport has a check mark in the column next to it. Click the column to add or remove detail callouts as needed. Deleting all detail callout instances does not delete the detail viewport, and new instances can be created at any time. However, deleting a detail viewport deletes all detail callout instances. |
| Activate | Navigates to the detail callout instance when an item with a check mark is selected; alternatively, double-click the item to navigate to the detail callout instance. To return from a detail callout instance to the associated detail viewport, click Navigate to Viewport from the Object Info palette of a selected detail callout. |
