Select all
             Command  |
             Path  |
             Shortcut  |
             Select All  |
             Edit Document context menu  |
             Ctrl+A (Windows) Cmd+A (Mac)  |
The Select All command selects all visible objects in editable layers and classes. The active layer is always editable, but other layers can be editable if they are visible and if the Layer Options are set to Show/Snap/Modify Others. For more information about setting layer and class visibility and layer and class options, see Columnas de visibilidad, La herramienta Visibilidad, and Configuración de la visibilidad global con opciones de clase y capa de diseño.
To select all objects in the drawing area:
Select the command. The program selects all visible objects that can be modified. Each of these selected objects is displayed with highlighting. Locked objects are also selected so they can be unlocked for modification.
