 Exporting calculation results
  | Command | Path |
| Export Braceworks Structure | Braceworks |
To export the results of the last calculation:
Select the command.
The Export Braceworks Structure dialog box opens.
| Parameter | Description |
| Export Format | Select whether to export to an .stp file in DSTV format or to a SCIA Engineer XML format |
| Load Combination | Select <No Load Combination> or choose a load combination. The icon next to the combination indicates whether it is class- or layer-based. |
| Selection | Select whether the exported results should include all rigging objects in the drawing, or only a subset of selected or visible objects |
