Inserting connections automatically
Command |
Workspace: Path |
Insert Drop |
Spotlight: Customize workspace to add command (see Personalización de los espacios de trabajo) Braceworks: Braceworks |
Selected rigging objects can be connected automatically with drops at likely connection points with the Insert Drop command.
To connect rigging objects automatically:
Select the two rigging objects to be connected.
Select the command.
The Select Hoist dialog box opens.
From the Resource Selector, select the hoist symbol for the drop.
The hoist symbol is inserted at possible connection points between the rigging objects.
