Hole pattern
Mode |
Tool |
Tool set |
Modes for The Symbol Insertion tool |
Hole Pattern
Detailing |
To insert a hole pattern:
Click the tool and mode.
Parameter |
Description |
Pattern |
Select a hole pattern
Number of Rows |
For rectangular hole patterns, enter the number of rows |
Vertical Spacing |
For rectangular hole patterns, enter the vertical spacing between the rows |
Number of Columns |
For rectangular hole patterns, enter the number of columns |
Horizontal Spacing |
For rectangular hole patterns, enter the horizontal spacing between the columns |
Number of Holes |
For bolt circle patterns, enter the number of holes |
Bolt Circle Dia. |
For bolt circle patterns, enter the diameter |
Hole Type |
Select the type of holes
Hole Size |
For round and tapped hole types, enter the hole size |
Slot Width |
For slotted hole types, enter the slot width |
Slot Length |
For slotted hole types, enter the slot length |
Counterbore/Countersunk |
Draws counterbore or countersunk holes
Diameter |
Indicates the diameter of the counterbore or countersunk holes |
Show Centerlines |
Displays the centerlines on the pattern
View |
Select the hole pattern view |
