Swing eye bolts
Mode
Tool
Tool set
Swing Eye Bolt
Fasteners
Multiple swing bolt and swing eye bolt tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a swing eye bolt:
Click the tool and mode.
Parameter
Description
Size
Specify the swing eye bolt size in diameter/threads per inch (imperial) or diameter/thread pitch (metric)
Eye Inside Dia
Specify the inside diameter of the eye
Outside Diameter
Specify the outside diameter
Length
Specify the length under the bolt head
Thread Length
Specify the thread length
Thread Style
(2D only)
Select the thread style; see Fastener object thread styles
View
(2D only)
Select the 2D view
Show Center Line
(2D only)
Draws the swing eye bolt with center lines
Show Threads
(3D only)
Draws the swing eye bolt with threads
Place Locus at Center
Draws the swing eye bolt with a center locus
Inserting fastener objects using the Fastener tool
Pernos
