U-bolts
Mode
Tool
Tool set
U-Bolt
Fasteners
The U-Bolt tool and U-Bolt - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a U-bolt:
Click the tool and mode.
Parameter
Description
Size
Specify the U-bolt size in diameter/threads per inch (imperial) or diameter/thread pitch (metric)
Inside Distance
Specify the inside distance between the ends of the U-bolt
Length
Specify the length from the inner portion of the “U” to the end of the legs
Thread Length
Specify the thread length
Thread Style
(2D only)
Select the thread style; see Fastener object thread styles
View
(2D only)
Select the 2D view
Show Center Line
(2D only)
Draws the U-bolt with center line(s)
Place Locus at Center
Draws the U-bolt with a center locus
Show Threads
(3D only)
Draws the U-bolt with threads
Inserting fastener objects using the Fastener tool
Pernos
