Wood screws
Mode
Tool
Tool set
Wood Screw
Detailing
The Wood Screw tool and Wood Screw - 3D tool share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a wood screw:
Click the tool and mode.
Parameter
Description
View
(2D only)
Select the 2D view
Series
Select inch or metric to display the appropriate nominal sizes
Head Type
Select the wood screw head type
Nominal Size
Select an inch or metric nominal size
Length
For a custom length value, deselect Use Standard Length Increments and enter the length under the screw head (or overall length for flat head screws)
Slot Type
Specify the slot type
Automatically adjusts the length to the nearest increment based on size; deselect to enter a custom length
Show Threads
Draws the wood screw with threads
Show Center Line
(2D only)
Draws the wood screw with center line(s)
Inserting fastener objects using the Fastener tool
Lag screws
Sheet metal screws
Thumb screws
