Parallel pins
Mode
Tool
Tool set
Parallel Pin
Fasteners
Multiple dowel pin and parallel pin tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a parallel pin:
Click the tool and mode.
Parameter
Description
Size
Select the parallel pin size
Pin Type
Select the pin type
Length
For a custom length, deselect Use Standard Length Increments and enter the length value
View
(2D only)
Select the 2D view
Show Center Line
(2D only)
Draws the parallel pin with center line(s)
Automatically adjusts the length to the nearest increment based on DIN standard sizes; deselect to enter a custom length
