Taper pins
Mode |
Tool |
Tool set |
Modes for The Symbol Insertion tool |
Fasteners |
Multiple taper pin tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a taper pin:
Click the tool and mode.
Parameter |
Description |
Size |
Select a taper pin size |
Length |
For a custom length value, deselect Use Standard Length Range (inch) or Use Standard Length Increments (DIN) and enter the desired length |
View (2D only) |
Select the 2D view
Show Center Line (2D only) |
Draws the taper pin with center line(s) |
Use Standard Length Range (inch only) |
Automatically constrains the length to the standard range per ASME specifications; deselect to enter a length value outside of the range |
Use Standard Length Range and Increments (DIN only) |
Automatically constrains the length to the standard range per DIN specifications; deselect to enter a length value outside of the range |
