Worm gears
             Mode  |
             Tool  |
             Tool set  |
             Modes for The Symbol Insertion tool  |
             Worm Gears
             Machine Components  |
Multiple worm and worm gear tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a worm gear:
Click the tool and mode.
             Parameter  |
             Description  |
             Circular Pitch  |
             Enter the circular pitch  |
             Number of Teeth  |
             Enter the number of teeth  |
             Pitch Diameter (Ref.)  |
             Displays the pitch diameter of the gear, based on the pitch and number of teeth  |
             Pressure Angle (deg.)  |
             Select the pressure angle in degrees  |
             Number of Starts (Worm)  |
             Select the number of starts of the worm  |
             Pitch Dia (Worm)  |
             Specify the worm pitch diameter  |
             Tooth Profile  |
             Select the type of tooth profile
             Face Width  |
             Enter the width of the gear face  |
             Draw Recess (2D only)  |
             Select Draw Recess to draw a recessed web, and specify the 2D parameters  |
             Web Thickness  |
             Enter the web thickness  |
             Recess Diameter  |
             Enter the recess diameter  |
             Recess Corner Radius  |
             Specify the recess corner radius  |
             Recess Fillet Radius  |
             Indicate the recess fillet radius  |
             Draw Hub (2D only)  |
             Draws a hub  |
             Hub Diameter  |
             Enter the hub diameter  |
             Hub Projection (Left/Right)  |
             Specify the amount of projection for the hub on both the left and the right; a negative value indicates that the hub face is recessed  |
             Hub Corner Radius  |
             Enter the hub corner radius  |
             Hub Fillet Radius  |
             Enter the hub fillet radius  |
             Draw Bore (2D only)  |
             Draws a bore  |
             Bore Diameter (2D and 3D)  |
             Enter the bore diameter  |
             Keyway  |
             If a keyway is present, select the square, rectangular, or custom size. The square and rectangular selections apply the ASME-recommended size based on the bore diameter.  |
             Width/Height  |
             For custom keyway sizes, enter the width and height values of the keyway  |
             Web Configuration (2D only)  |
             Select the gear configuration and then specify the 2D parameters, if any. When Holes is selected, hole size can be specified as a percentage or diameter value.
             Number  |
             Indicate the number of holes or spokes for the gear (does not apply to Plain web configurations)  |
             Size (10–100%)  |
             For Holes (Percent) and Spokes web configurations, enter the percentage of the recess opening occupied by the holes or spokes  |
             Center Distance  |
             When Holes is selected for the web configuration, specify the distance between the hole centers  |
             Hole Diameter  |
             When Holes is selected for the web configuration, indicate the size of the holes  |
             View (2D only)  |
             Select the 2D view
             Show Center Lines (2D only)  |
             Draws the gear with center lines  |
