 Geneva mechanism
Geneva mechanism
  The Geneva mechanism device, which is created using one of the Geneva Mechanism templates provided with the Vectorworks software, produces intermittent rotational motion of the driven part (index plate) while the driver rotates at a constant speed.
The recommended procedure to include a Geneva mechanism in an existing Vectorworks drawing is to create it in a separate document and then copy and paste it into the drawing and convert it to a group by selecting it and selecting Modify > Convert > Convert to Group.
To create a Geneva mechanism object:
Select File > New.
The Create Document dialog box opens.
Select Use document template, and choose the Geneva Mechanism (Imperial).sta or Geneva Mechanism (Metric).sta template.
For version 2019 and later, the required .sta files are located in the [Vectorworks]\Libraries\Objects - Miscellaneous_Entourage\Machine Design\Templates folder. Copy the template file you need into your [User]\Libraries\Defaults\Templates folder.
The new file opens with a Geneva mechanism inserted by default. The Geneva mechanism’s properties can be edited from the Object Info palette.
| Parameter | Description |
| Number of Points | Enter the number of points on the index plate |
| Center Distance | Enter the distance between the center of the index plate and the driver |
| Follower Dia. | Enter the follower diameter |
| Cam Clearance | Enter the cam clearance |
| Cam Dia. | Enter the cam diameter |
| Driver Dia. | Enter the driver diameter |
| Index Plate Dia. (Ref.) | Displays the diameter of the index plate |
| Follower Dist. (Ref.) | Displays the follower distance |
| Cam Cutout Radius (Ref.) | Displays the cam cutout radius |
| Lighting Holes | Places lighting holes on the driver |
| Number | Enter the number of lighting holes |
| Diameter | Enter the diameter of the lighting holes |
| Center Distance | Enter the distance between the center of the lighting holes about the driver |
| Show Center Marks | Places center mark symbols on the index plate and cam/driver |
| Show Center Lines | Draws the index plate and cam/driver with center lines |
