Tapered roller bearings
Mode
Tool
Tool set
Tapered Roller Bearing
Machine Components
Multiple ball bearing, roller bearing, and needle bearing tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a tapered roller bearing:
Click the tool and mode.
Parameter
Description
Bearing Type
Select from a variety of bearing types
Inside Diameter
Specify the inside diameter of the bearing
Outside Diameter
Specify the outside diameter of the bearing
Width of Inner Ring
Enter the width of the inner ring
Width of Outer Ring
Enter the width of the outer ring
Space Between Rows
Enter the space between rows
Inner Ring Projection
Specify the projection distance of the inner ring
View
(2D only)
Select the 2D view
Show Retainers
Displays the bearing with retainers; Show Detail must also be selected in order to view the retainers in 2D bearings
Show Detail
(2D only)
Indicate whether to display a detailed 2D view of the bearing (including balls and/or retainers)
Show Center Line
(2D only)
Draws the bearing with center lines
Section
(3D only)
Draws a section of the bearing
Highlight Rollers
(3D only)
Highlights the rollers within the bearing in black
