Torsion springs: Front view
Mode
Tool
Tool set
Torsion Spring - Front
Machine Components
Multiple torsion spring tools share the same position on the tool set. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
To insert a torsion spring - front view:
Click the tool and mode.
Parameter
Description
Outside Diameter
Specify the outside diameter of the coiled section of the torsion spring
Wire Diameter
Enter the wire diameter
Number of Active Coils
Specify the number of active coils in the spring
Left/Right End
Select to enter the dimensions for left and/or right end
Length
For each end, specify the length between the coil center and the end
Direction
Indicate whether each end is facing up or down
Orientation
Select forward, rearward, or normal for each end
Spiral
Select either a Left Hand or Right Hand spiral direction
