Feature control frame
Mode |
Tool |
Tool set |
Modes for The Symbol Insertion tool |
Feature Control Frame
Dims/Notes |
Multiple annotation tools share the same position on the tool set in some workspaces. Click and hold the mouse on the visible tool to open the Pop-out tools list and select the desired tool.
A feature control frame consists of a geometric characteristic symbol, up to two tolerance areas, and up to three datum reference areas.
To insert a feature control frame:
Click the tool and mode.
To add a leader and marker, click the Selection tool from the Basic palette and drag the control points on the object. Edit the marker from the Attributes palette (see Atributos de indicador).
Parameter |
Description |
Rotation |
Specifies the number of degrees to rotate the object (0.00 is horizontal) |
Text Style |
Select a text style from a library or the current file. To use the style defined for the object’s class, select <Class Text Style>. To format the text using options on the Text menu, select <Un-Styled>. See Using text styles and Formatting text. |
Geometric Characteristic |
Select the geometric characteristic symbol, if any
Composite Box |
Increases the size of the geometric characteristic box; this is used when placing a second feature control frame
Tolerance Area #1/#2 |
Includes Tolerance Area #1 and/or Tolerance Area #2 |
Tolerance |
Enter the tolerance value |
Show Diameter Symbol |
Displays a diameter symbol along with the tolerance value
Material Condition |
Choose the material condition, if any
Statistical Tolerance |
Displays a statistical tolerance symbol
Projected Tolerance Zone |
Displays a projected tolerance zone symbol |
Zone Height |
Enter the maximum projected tolerance zone height when a projected tolerance zone symbol is displayed |
Place the PTZ symbol outside the FCF |
Places the projected tolerance zone symbol outside and to the bottom of the feature control frame
Primary/Secondary/Tertiary Datum Reference |
Includes the primary, secondary, and/or tertiary datum reference |
Reference |
Enter the desired reference letter |
Select a material condition, if any
Leader Position |
Select left or right |
