Arch02176.pngEnergos advanced project settings: Building Envelope pane
The Building Envelope pane specifies the various building elements, such as walls, roofs, and so on, to include in the calculations. From here, default building element data can also be overridden. Ground and thermal bridge information is also specified.
Parameter
Description
Collect Elements
Specify whether building information from all layers and/or classes should be analyzed, or whether elements from only certain layers and classes should participate in energy analysis calculations. If only specific layers should be included, choose On Specific Layers and then click Layers to specify which layers to use from the Select Layers dialog box. If only specific classes should be included, choose In Specific Classes and click Classes to select the classes to include from the Select Classes dialog box.
Building Elements
Lists the building elements (based on the selected layers and classes) that are included in the energy calculations
Edit Building Elements List
Opens the Edit Building Elements List dialog box, for modifying the list of included building elements as described in Editing the included building elements
Ground
Indicates the thermal properties of the ground at the building site
Thermal Conductivity
Specifies the thermal conductivity property of the ground at the building site
Heat Capacity
Indicates the heat capacity of the ground at the building site
Phase Shift
Indicates the ground temperature phase shift; this value overrides any thermal bridge calculations for the perimeter insulation
Thermal Bridges
Thermal bridges can account for significant energy loss even from energy efficient buildings; the list of thermal bridges that participate in the building envelope transmission loss can have positive or negative values.
Create a record format named Thermal Bridge with relevant record fields and values; when attached to drawing objects, these objects automatically display in the list of thermal bridges.
Automatic Calculation Based on the Thermal Bridges List
Once thermal bridges and their parameters have been listed, automatically calculates their effect on energy loss
Manual Input
Overrides the list of thermal bridges and their parameters with a manually input percentage value
Edit Thermal Bridges List
Opens the Edit Thermal Bridges List dialog box, for managing the list of thermal bridges as described in the following section
Editing the thermal bridges list
To edit the list of thermal bridges that affect the project:
From the Building Envelope pane, click Edit Thermal Bridges List. The Edit Thermal Bridges List dialog box opens.
Parameter
Description
Lists the thermal bridges and their parameters
Add
Opens the Edit Thermal Bridge dialog box, for adding a new thermal bridge to the list. Enter a name for the list and indicate the number of bridges at that location. Select the location from the list. Specify the length and PSI of the thermal bridge. The thermal bridge is added to the end of the list.
Edit
Opens the Edit Thermal Bridge dialog box, to edit the parameters of the currently selected thermal bridge
Delete
Deletes the currently selected thermal bridge from the project
Análisis de energía avanzado
Análisis de energía básico
Energy analysis parameter dependencies
Energos results
Energos overview
