Arch02177.pngEnergos advanced project settings: Building Spaces pane
On the Building Spaces pane, indicate data related to space objects that make up the building envelope. From here, default space data can also be overridden.
Parameter
Description
Collect Spaces
Specify whether space information from all layers and/or classes should be analyzed, or whether spaces from only certain layers and classes should participate in energy analysis calculations. If only specific layers should be included, choose On Specific Layers and then click Layers to specify which layers to use from the Select Layers dialog box. If only specific classes should be included, choose In Specific Classes and click Classes to select the classes to include from the Select Classes dialog box.
Total Relevant Floor Area
Automatic Calculation
Calculates the relevant floor area from the space objects in the drawing (based on the selected layers and classes)
Manual Input
Enter the floor area value manually, overriding the automatic calculation
Total Volume
Calculates the space volume from the space objects in the drawing (based on the selected layers and classes)
Manual Input
Enter the volume value manually, overriding the automatic calculation
Edit Spaces List
Opens the Edit Spaces List, for modifying the list of included spaces as described in Editing the included spaces
Análisis de energía avanzado
Análisis de energía básico
Energy analysis parameter dependencies
Energos results
Energos overview
