Arch02183.pngEnergos advanced project settings: Systems Cooling pane
The cooling system and cooling distribution system are specified on the Systems Cooling pane.
Parameter
Description
Include Cooling System
Includes the cooling system in the energy calculations
Primary System
Coverage
Displays the percentage of the building that is cooled by the primary cooling system based on whether there is a secondary system and what its coverage percentage is. If there is no secondary system, the primary system automatically covers 100%.
System
Select a cooling category, and then a cooling system. The system list can be modified; see Specifying system sets.
Additional Air Change Rate
When an additional centralized ventilation system is installed, select this option to match the required demand, and specify the air change rate
Humidification/Dehumidification
When either humidification or dehumidification is part of the cooling system, select this option and select a system. The system list can be modified; see Specifying system sets.
Secondary System
To include a secondary system, set a coverage value other than 0 (zero) percent
Coverage
Indicates the percentage of the building that is cooled by the secondary system
System
Select a secondary cooling category, and then a cooling system. The system list can be modified; see Specifying system sets.
Include Cooling Distribution System
Includes the cooling distribution system in the energy calculations; the cooling system must already be included
System
Select a cooling distribution system. The system list can be modified; see Specifying system sets.
Automatic Ductwork Length Estimation Based on Building Type and Size
Select this option to automatically estimate the distribution system’s ductwork length based on the building information
Manual Ductwork Length
Select this option to manually enter the duct length value
Análisis de energía avanzado
Análisis de energía básico
Energy analysis parameter dependencies
Energos results
Designación de objetos de dibujo como sistemas personalizados de Energos
Energos overview
