Arch02184.pngEnergos advanced project settings: Systems Hot Water pane
Indicate the specifics of the hot water system and hot water distribution system on the Systems Hot Water pane.
Parameter
Description
Include Main Hot Water System
Includes the main hot water system in the energy calculations. If the water is heated by the same system as the heating system, indicate this by selecting the appropriate type of hot water heating system from the System list.
Primary System
Coverage
Displays the percentage of the building with water heated by the primary system based on whether there is a secondary system and what its coverage percentage is. If there is no secondary system, the primary system automatically covers 100%.
System
Select a water heating category, and then a heating system. The system list can be modified; see Specifying system sets.
Secondary System
To include a secondary system, set a coverage value other than 0 (zero) percent
Coverage
Indicates the percentage of the hot water system that is heated by the secondary system
System
Select a secondary water heating category, and then a heating system. The system list can be modified; see Specifying system sets.
Include Hot Water Distribution System
Includes the hot water distribution system in the energy calculations; the hot water system must already be included
System list
Select a hot water distribution system. The system list can be modified; see Specifying system sets.
Automatic Pipework Length Estimation Based on Building Type and Size
Select this option to automatically estimate the distribution system’s ductwork length based on the building information
Manual Pipework Length
Select this option to manually enter the pipework and exhaust air duct length values through the warm (heated) area of the building and up to two unheated or outdoor zones
Análisis de energía avanzado
Análisis de energía básico
Energy analysis parameter dependencies
Energos results
Designación de objetos de dibujo como sistemas personalizados de Energos
Energos overview
