Arch02181.pngEnergos advanced project settings: Systems Ventilation pane
Specify all the parameters related to building ventilation on the Systems Ventilation pane.
Parameter
Description
Include Ventilation System
Includes the ventilation system in the energy calculations
System Type
Select whether the system is a Mechanical Heat-Recovery Ventilation (MHRV) or pure extract system
Operation Modes
Select a typical operation mode. The system list can be modified; see Specifying system sets.
System Design Results
Displays the results for the ventilation system; update the energy analysis calculations to view the latest system design results
System Selection
Select a ventilation system. The system list can be modified; see Specifying system sets.
Include Summer Ventilation
When summer ventilation involves different system operation or specifications, select the option and click Advanced to specify the parameters
Advanced
Opens the Advanced Ventilation Settings dialog box, as described in the following section
Include Ventilation Distribution System
Includes the ventilation distribution system in the energy calculations; the ventilation system must already be included
System List
Select a ventilation distribution system. The system list can be modified; see Specifying system sets.
Automatic Estimation Based on Building Type and Size
Select this option to automatically estimate the distribution system’s ductwork length based on the building information
Manual Input
Select this option to manually enter the pipework and exhaust air duct length values
Specifying advanced ventilation system settings
When specific ventilation parameters are required, or summer ventilation requirements are different, set the advanced ventilation parameters.
To specify the advanced ventilation parameters:
From the Systems Ventilation pane, click Advanced. The Advanced Ventilation Settings dialog box opens.
Parameter
Description
General tab
Demand
Determines whether air demand per person and extract air demand should be automatically calculated or use the manually entered value; enter the value if manual input is selected
Ground Source Heat Exchange Efficiency
Specifies the efficiency of the ground source heat exchange for the ventilation system
Summer tab
Specifies the summer ventilation parameters, which are taken into account when Include Summer Ventilation is selected on the Systems Ventilation pane. Windows that participate in summer ventilation also have advanced parameters to be set on the Window Settings - Energos pane as described in Window settings: Energos pane.
Type
Select the summer ventilation system (manually or automatically controlled)
Inside Thermal Envelope
Indicates whether the summer ventilation system is within the thermal envelope and will be considered for energy calculations. If it is outside the building envelope, it is not part of the building energy balance calculation but it is still be part of the primary energy calculation since it uses energy.
Minimum Acceptable Indoor Temperature
This is the baseline from which the overheating maximum is calculated. In hot climate zones (depending on humidity) an 8 Kelvin temperature difference is usually acceptable and is referred to as cooler than the external environment. The cooling target baseline can be moved up without reducing comfort levels to the user.
Mechanical Ventilation
Specifies the air change rate information for the summer ventilation
Overheating Limit
Indicates the overheating temperature limit
With Heat Recovery
Select this option when the summer ventilation also includes heat recovery capacity
Spec. Capacity
Indicates the specific capacity of the actual building structure. The heavier a building (bricks and mortar, or concrete), the more energy the structure buffers during heat peaks.
Day GF/Day UF/Night
These tabs specify the manual cooling options (manually opening windows) for the ground floor and upper floor for a portion of the day, and for all floors at night
Fraction Of Operation
Indicates the percentage of time that the windows are open
Temperature Diff Interior - Exterior
Specifies the difference in temperature between the interior of the building and the outdoor ambient temperature
Wind Velocity
Indicates the speed of the wind coming through any open windows. The wind speed is normally 0 (zero) during summer nights as there is little temperature difference between the interior and exterior to generate non-mechanical wind.
Análisis de energía avanzado
Análisis de energía básico
Energy analysis parameter dependencies
Energos results
Designación de objetos de dibujo como sistemas personalizados de Energos
Energos overview
