Energos basic project settings: Setup pane
The Setup pane establishes the basic building site location and main project settings.
Parameter |
Description |
Available Parameters |
Select the level of detail for the energy analysis parameters. Basic: The parameter set is sufficient for generalized energy analysis Advanced: Enables the display of additional, detailed panes in the project settings, for expert users who wish to specify parameters to a high level, as described in Análisis de energía avanzado |
Project Location from Heliodon |
The project location is automatically obtained from a known location close to that of the heliodon object, that is matched to Energos climate and location data; however, an alternative location can be selected from the list. Any advanced locations that have been specified are listed. |
Location |
The selected location is displayed below the list |
To specify a location that is different from the heliodon’s location, or to specify detailed climate data, click Advanced Location. The Advanced Location dialog box opens. Click Location and choose a different location’s climate information. Alternatively, click Custom to choose a custom location set from those you have defined, as described in the following section. |
Project |
Contains information about the project; while most fields are for informational purposes only, the Altitude does affect the energy calculations |
Name/Description |
Enter the name of the project and a brief description |
Altitude |
Specify the altitude above sea level of the project’s ground level (where slabs are located); this value comes from the climate data, but can be overridden by entering a different value here |
Architect |
Enter details about the architect or architectural firm |
Services Engineer |
Enter details about the services engineer or engineering firm |
Year of Construction |
Indicate the year of construction for the project |
Creating custom location sets
Instead of using one of the default locations and its associated climate information, detailed climate information sets can be specified and edited, and then the climate information from one of the custom locations can be selected for use instead of heliodon climate information.
To specify custom location sets:
From the Setup pane, click Advanced Location.
Click Custom and select Edit List from the Custom list.
The Edit Location List dialog box opens.
Parameter |
Description |
System Set |
Lists the defined system sets. When one is selected, the associated system names are listed in the system list, where they can be edited and added to; edited system sets are saved in the user folder and are indicated with (user folder) appended to the system set name. |
Rename |
Opens the Rename List Set dialog box; provide a new name for the system set. Default system sets that are included with Vectorworks cannot be renamed. You are prompted to rename a copy of the set, which is saved in the user folder. |
Delete |
Deletes the selected set from the System Set list; default system sets that are included with Vectorworks cannot be deleted |
System list |
Lists the systems that are included in the selected System Set |
New |
Adds a new system to the system set as described in the following section |
Edit |
Edits the currently selected system as described in the following section |
Duplicate |
Creates a duplicate of the currently selected system, as described in the following section |
Delete |
Deletes the selected system from the set |
Set As Default |
Sets the currently selected system and system set as the default for new files |
Click New to create a new system, or select a system and click Edit or Duplicate.
If a new system is to be created, or a currently selected system is duplicated, the New System dialog box opens. Select an existing system set for the system, or slick Save to a System Set and specify a new system set name.
If a default system is selected for editing, you are prompted to duplicate it; default systems cannot be edited. New or edited systems are saved in the user folder.
The Edit Location Information dialog box opens.
Parameter |
Description |
General tab |
Location |
Country/City |
Enter the name of the country and city of the building site; the names display in the Setup pane for reference when an advanced location is specified |
Longitude |
Specify the longitude of the location in degrees |
Latitude |
Specify the latitude of the location in degrees |
Altitude |
Specify the location’s altitude above sea level |
Building Site |
Site Elevation |
Select Site Elevation and enter an elevation value for the building site, only if the building site altitude is significantly different from the altitude of the weather station used to determine climate data |
Outside Temperature |
Specify the annual average temperature for the location |
Unheated Space Temperature |
Specify the average temperature of an unheated/uncooled area within the building envelope |
Daily Summer Temperature Swing |
Enter the typical daily temperature range (difference between high temperature and low temperature) that occurs during the summer at the location |
Depth of Groundwater Table |
Specify the depth of the groundwater table at the location |
Groundwater Flow Rate |
Indicate the flow rate of the groundwater at the location |
Properties tab |
Transfer to Annual Method |
HT |
Specifies the length of the heating period during the day, per year |
GT |
Specifies the heating degree days per year, which is the sum of the temperature difference between the interior and exterior |
Global Radiation |
Indicate the amount of solar radiation for the site |
North/East/South/West/Global |
For each direction and globally, specify the amount of solar radiation that affects the site |
Heating/Cooling Loads tab |
Solar radiation has an effect on heating and cooling based on the location and site of the building. The more glazing towards the sun, the more energy is gained, so the gains and losses are calculated based on orientation. |
Heating Load |
Specifies the amount of energy needed for a building or space to maintain an internal temperature with a certain set of external conditions or weather |
Weather 1/Weather 2 |
The two different weather conditions mainly affect solar gains during the winter; one condition might be for a warmer winter and one for a more cloudy/cool winter |
Cooling Load |
Specifies the amount of energy to be removed from the space |
Temperature |
Indicates the ambient, sky, and ground temperatures |
Radiation/Temperature tab |
Radiation and temperature data represent annual fluctuations for the custom location |
Include Ground Temperature Data |
Select this option to include ground temperature climate data |
Radiation/Temperature Data Graph |
Each of the parameters selected in the Legend is graphed over a one-year period; the radiation Y-axis on the left applies to the Radiation parameters, and the Temperature Y-axis on the right applies to the Temperature parameters |
Selected Point |
Displays the data for the point selected on one of the graphs; the data can be edited by entering a new value or dragging the selected point |
Legend |
Shows the parameters selected for display on the graph, and their color key. Deselect parameters to reduce clutter when adjusting the data for one of the parameters. |
Click OK when the custom location information has been added or edited.
In the Edit Location List dialog box, select the system to use. Click Close.
In the Advanced Location dialog box, the custom system is selected.
On the Setup pane of the Energos Project Settings dialog box, the project location displays as being determined by an advanced location (overriding the heliodon location), and the location name displays below the list.
