Arch02170.pngEnergos basic project settings: Systems pane
From the list of default configurations, select a systems configuration that most closely matches the project.
Localized energy data may not be available in your country; check with your local distributor.
The selected systems configuration pre-defines types of heating, cooling, ventilation, and hot water systems. For basic energy analysis, these pre-configured values offer good typical calculation parameters for the selected type of systems. For advanced analysis, the suggested parameters can be changed from the various panes and saved; see Energos advanced project settings: Systems pane.
Análisis de energía avanzado
Análisis de energía básico
Energy analysis parameter dependencies
Energos results
Energos overview
