Energos basic project settings: Usage pane
From the list of default configurations, select a usage configuration that most closely matches the project.
Localized energy data may not be available in your country; check with your local distributor.
The selected usage configuration pre-defines electricity usage patterns and other factors such as building thermal conductivity, heat capacity, phase shift (for example, water evaporation), typical thermal bridges, and airtightness factors. For basic energy analysis, these pre-configured values offer good typical calculation parameters for the selected type of usage. For advanced analysis, the suggested parameters can be changed from the various panes. When the parameters have been modified, the configuration indicates this. When advanced Energos parameters have been enabled from the Setup tab, the modified configuration can be saved.
