Arch02244.pngExporting energy analysis results
Command
Path
Export Energy Data
AEC > Energos
The detailed results of the energy analysis calculations, along with the building envelope and project information, can be exported to a comma-delimited file (.csv) or tab-delimited file (.txt), which can then be opened in a spreadsheet program or sent for certification. Export all of the data, or select specific data sets for export.
To export the energy analysis results:
Select the command.
The Export Energy Data dialog box opens.
Parameter
Description
Saved Settings Options
See Using saved sets to save and apply saved settings; <All Data> exports all of the energy analysis data
Data list
Show
A check mark in the Show column indicates that the data will be exported
Disclosure arrow
Each set of data is grouped into categories; when the category heading is selected in the Show column, all of the category’s data exports.
Placing a check mark in a heading category automatically selects all sub-categories for export. To select or deselect specific data within the category, click the disclosure arrow. The category expands, listing all data for individual inclusion in or exclusion from export.
Name
Lists the data sets by name
Select the data to export from the Export list.
Specify a location to save the file, and select the type of file (Comma Delimited or Tab Delimited).
Energos results
