Exporting OBJ
Command
Path
Export OBJ (3D only)
File > Export
Vectorworks products export OBJ files for use in 3D modeling and visualization workflows.
To export an OBJ file:
If 3D objects from only one layer should be exported, make that layer active. If only selected objects should be exported, select the objects.
Select the command.
The Export OBJ Options dialog box opens.
Parameter
Description
Export
Selected Objects Only
Exports only selected 3D objects
All Objects in Current Layer
Exports all visible 3D objects from the current layer (including objects in design layer viewports)
All Visible Objects in All Layers
Exports all visible 3D objects from all layers in the Vectorworks file (including objects in design layer viewports)
Quality
Set the conversion quality of 3D objects that have curved surfaces.
Quality is determined by the number of polygons in the export; using fewer, larger polygons results in lower quality. Exporting more polygons slows down the export and increases the size of the output file.
Apply Double Side Faces
Applies double sided faces.
This setting allows you to view a model from all sides, even if double-sided rendering is off. Selecting this setting increases file size.
Select the export options.
Specify the export file name and destination.
A folder containing all OBJ contents is created in the location specified.
