Exporting Metafile format
Command Path
Export Metafile
File > Export
Graphics files can be exported in Metafile format for inclusion in virtually any Windows program, including AutoCAD and word processing programs.
This section only applies to Windows users. The Vectorworks program supports the enhanced version of the Windows metafile format.
To export a Metafile:
Select the command.
The Export Metafile dialog box opens.
Set the desired Resolution.
In addition to rendered design layers and Vectorworks geometry, the Resolution setting affects PDF objects, which are rasterized when exported to Metafile format.
Specify the export file name and destination.
