Exporting STEP
Command
Path
Export STEP (3D only)
File > Export
The Export STEP (3D only) command exports 3D curves, surfaces, and solids from a Vectorworks files into STEP format. Closed solids export as solids, while open solids export as a collection of surfaces.
Exportable objects
3D loci
3D polygons
3D symbols
Chamfers
Fillets
Groups
Parametric objects
NURBS curves and surfaces
Shells
Sweeps
Architectural objects (wall/slab/column/stair)
CSG solids (add/subtract/intersect/section)
Extrudes and multiple extrudes
Solids (sphere/cone/hemisphere)
To export a STEP file:
Select the command.
The Export Options dialog box opens.
Select Export Solid as Trimmed Surfaces to export a solid as several different “bodies” (for example, a cube exports as six bodies); otherwise, a solid is exported as a single body.
Specify the file name and destination.
