Exporting a VGX 3D model
Command
Path
Export VGX (3D only)
File > Export
Vectorworks exports 3D models in a VGX format that can be viewed on the Vectorworks Cloud services web portal and the Nomad mobile app, in Unity®-based 3D and augmented reality (AR) views.
To export a VGX 3D model:
In a design layer, set the desired initial 3D view, including class and layer visibility, and a clip cube if desired. Only visible classes and layers are exported.
Select the command.
Alternatively, use the Generate 3D Model command on the Vectorworks Cloud Services web portal, the desktop app, or the Nomad mobile app.
Because 3D models are always processed on Vectorworks Cloud Services, the Generate 3D model dialog box opens on the cloud, to control the file size, performance, and appearance. If you are not currently logged in to Vectorworks Cloud Services, you are prompted to log in before proceeding.
Click to show/hide the parametersClick to show/hide the parameters
Parameter
Description
Resolution of curved surfaces
Sets the desired geometry quality
Clip cube
When the Vectorworks model uses a clip cube in the view for export, Clip cube optimization excludes objects that are entirely outside the clip cube
Save as
Specify the location and the file name
The job status displays on the Vectorworks Cloud Services desktop app and web portal.
See the online help for Vectorworks Cloud Services and Nomad to view, navigate, share, and manipulate the exported 3D model.
Concepto: visibilidad de los elementos de dibujo
Viewing a model with the clip cube
