Exporting as a database
Command |
Path |
Export Database |
File > Export |
The Export Database command exports all records of a particular format as a file that can be used in a database program, such as FileMaker Pro and Microsoft Access. The Vectorworks program provides a variety of formats to select from when exporting records as a database, including comma-delimited, tab-delimited, merge, DIF, and SYLK.
To export the selected records to a database:
Select the command.
The Export Database dialog box opens.
Select the records to export and the format for the export file.
Specify the export file name and destination.
