Exporting in Rhino 3DM format
| Command | Path |
| Export Rhino 3DM (3D only) | File > Export |
The Export Rhino 3DM (3D only) command exports 3D curves, surfaces, and solids from a Vectorworks file into Rhino 3DM format, used by Rhinoceros model files. Closed solids are exported as solids, while open solids are exported as a collection of surfaces.
| Exportable objects | |
| 3D loci 3D polygons 3D symbols Chamfers Fillets Groups Parametric objects | NURBS curves and surfaces Shells Sweeps Architectural objects (wall/slab/column/stair) CSG solids (add/subtract/intersect/section) Extrudes and multiple extrudes Solids (sphere/cone/hemisphere) |
To export a Rhino 3DM file:
Select the command.
The Export Options dialog box opens.
Select Export Solid as Trimmed Surfaces to export a solid as several different “bodies” (for example, a cube exports as six bodies); otherwise, a solid is exported as a single body.
Specify the file name and destination.
