Exporting scripts
Exporting a simple VectorScript
Command |
Path |
Export Simple VectorScript (3D only) |
File > Export |
You can export 3D drawing objects as a Pascal-like script designed to be easy to import into other design programs, such as Strata software products.
To export a simple VectorScript file:
Select the command.
Select whether to export in front view or in the current view.
Specify the export file name and destination.
Exporting scripts
Command |
Path |
Export Script |
File > Export |
The Export Script command writes out the contents of the current file as a script. The script can then be imported into another file, used as part of another script, or studied as a guide for learning. See Using scripts.
To export a script:
Select the command.
