Getting shareable links of panoramic views
If Get Shareable Link is selected when you export a panoramic view, the Shareable Link dialog box opens after the view is generated.
Select the methods for sharing the view, and then click Done.
Parameter |
Description |
QR Code |
Displays a QR code that links to the panoramic view; click Copy Image to copy the image to the clipboard to share |
Link |
Displays a URL that links to the panoramic view; click Copy Link to copy the URL to the clipboard to share |
Hyperlink plug-in objects |
Creates a hyperlink object to place on the drawing that links to the panoramic view, or updates an existing hyperlink object with a new destination (see Inserción de hipervínculos) |
Update existing Hyperlink plug-in object |
Updates an existing hyperlink anywhere in the drawing; select the unique Label assigned to the hyperlink to update |
Create new Hyperlink plug-in object |
Creates a new hyperlink object in the drawing; specify a unique Label for the hyperlink; select the layer to create it on, and select a symbol definition for the hyperlink. Some available symbol definitions include QR codes, and a viewer graphic image, to convey that the link is to a panoramic view. |
