Arch02861.pngInserting fireplaces
Mode
Tool
Tool set
Fireplace
Furn/Fixtures
The Fireplace tool provides access to a variety of standard fireplace configurations available from the Resource Manager, in addition to individual objects created using the tool. The tool can be used to create your own fireplace styles (see Concepto: estilos de objeto de complemento).
To insert a fireplace:
Click the tool and mode.
Do one of the following:
Click Active Def on the Tool bar to select a resource from the Resource Selector.
Click Preferences to open the object properties dialog box and specify the tool’s default parameters.
The parameters can be edited later from the Object Info palette.
Parameter
Description
Style
Replace, remove, or edit the current style, or create a new plug-in object style for this object.
Editing a style changes all instances in the file that use the style.
Hide Style Parameters
Hides the parameters that are set by style; these cannot be edited from the dialog box or Object Info palette
Config
Select the fireplace configuration
Unit/Rear Width
Enter the width of the front and rear faces of the fireplace
Unit Depth
Enter the fireplace overall depth
Opening Width/Height
Enter the firebox width and height.
The width is centered; the height is measured from the firebox floor.
Unit Height
Enter the overall fireplace height
Floor Height
Enter the height of the firebox floor
Flue
Select the position of the flue
Flue Diameter/Offset
Enter the flue diameter and offset.
The offset positions the center of the flue relative to the back edge (if the flue is set to Top) or the top edge (if the flue is set to Back) of the overall unit.
Sleeve Height
Enter the height/length of the flue’s sleeve
Penthouse Height/Offset
For two- or three-sided fireplaces, enter the height and offset of the penthouse
Click on the drawing to place the object, and click again to set the rotation.
Optionally, create a style resource from the object (see Standard plug-in object styles without catalog options).
Resource Selector
La paleta Información del objeto
Symbols within a wall
