Importing file contents as symbol definitions
For the following file types, you can use the specific Import [file type] command to directly import the contents of an individual file as a symbol definition in the Resource Manager; for more information, see Resource Manager and Concept: Vectorworks symbols.
DXF
DWG
3ds
IGES
OBJ
SAT
STEP
STL
Rhino 3DM
Parasolid X_T
SketchUp
Importing symbols as a batch
Command
Path
Import Symbol (Batch)
File > Import
Resource Manager > Action
The Import Symbol (Batch) command imports multiple files or folders containing files into the Resource Manager. The contents of the imported files are saved as symbol definitions.
To import one or more files or folders as symbol definitions:
Select the command.
The Import Symbol (Batch) dialog box opens.
Parameter
Description
Select one or more files
Imports certain files within a folder. Click Choose Files and choose one or more files to import. The number of files selected is displayed.
Select a folder
Imports all files from a specified folder. Click Choose Folder and choose the source folder. The folder name and location are displayed.
Import from subfolders
Imports files from all subfolders of the the selected folder
Create symbol folders for subfolders
Creates a symbol folder in the Resource Manager for every subfolder of the selected folder
Assign to Class
Select the class for the imported symbols, or create a new class
Insertion Point
Select the insertion point for the imported symbols
Options
Opens the Import Symbol (Batch) Options dialog box to specify import options for some file formats
Click Options to specify import information for some file types based on their format.
The Import Symbol (Batch) Options dialog box opens.
Parameter
Description
File format pane
Click a file format to specify import options for that file type
Import materials
(3DS/OBJ/SketchUp)
Imports material and texture information from the files as Renderworks textures, and/or creates Renderworks textures for all materials from the files
Import mesh objects
(3DS only)
Imports object geometry from each 3ds file as a mesh object or as groups of 3D polygons
Import the geometry from the file as
(SketchUp only)
Imports object geometry from each SketchUp file as a mesh object or as groups of 3D polygons
Click OK to return to the Import Symbol (Batch) dialog box.
Click Import.
The progress of the import is displayed for each imported file during import. The final results of the import process are displayed in the Import Symbol (Batch) Results dialog box.
Click Details to open the results log file. The log text file, named ImportAsSymbolLog, is placed in the Vectorworks user folder. The report provides a summary of the import, including a list of which files succeeded, and which failed.
Opciones para importar archivos DXF/DWG y DWF
Importing 3ds
Importing IGES
Importing OBJ
Importing SAT
Importing STEP
Importing STL
Importing Rhino 3DM
Importing Parasolid X_T
Importing SketchUp
