Moving objects in 3D space
Command
Path
Shortcut
Move 3D
Modify > Move
Ctrl+Alt+M (Windows)
Cmd+Option+M (Mac)
To move an object in 3D space by command:
Select the object to move.
Select the command.
The Move 3D Selection dialog box opens.
Parameter
Description
Cartesian
Select the X, Y, Z (Cartesian) coordinate system
X, Y, Z Offset
For Cartesian coordinates, specify the distance to move the object
Working Plane
Select the X’, Y’, Z’ (working plane) coordinate system
X’, Y’, Z’ Offset
For working plane coordinates, specify the distance to move the object
The object is moved in 3D space according to the criteria specified.
Moving objects
