Moving objects in the screen plane
Command |
Path |
Shortcut |
Move |
Modify > Move |
Ctrl+M (Windows) Cmd+M (Mac) |
For information about moving symbols in walls (Design Suite required), see Moving symbols in walls with the Move command.
To move an object in screen plane space by command:
Select the object to move.
Select the command.
The Move Selection dialog box opens. Move the object according to Cartesian or polar coordinates.
Parameter |
Description |
Cartesian |
Specify the distance to move the object; for Cartesian coordinates, select Cartesian and enter the X and Y Offset distances |
Polar |
Specify the distance to move the object; for polar coordinates, select Polar and enter the Distance and Angle |
The object is moved the specified distance.
