Trimming and clipping objects
Trim command
| Command | Path | Shortcut |
| Trim | Modify | Ctrl+T (Windows) Cmd+T (Mac) |
Use the Trim command to trim lines or walls where they intersect with another object.
To trim objects:
If necessary, position the trimming object over the object to be trimmed.
Select the trimming object.
Select the command.
Click the object to be trimmed.
The trim command is executed and the pieces can be moved independently.
