Permission levels for document preferences and settings
Setting or preference |
Permission to modify |
Permission to commit |
Refresh updates working file |
Display (Document Preferences) |
Black and white only |
Layers-Restricted |
Project |
Yes, if not modified |
Auto-display detail levels for design layers |
Layers-Restricted |
Project |
Save viewport cache |
Layers-Restricted |
Project |
Save VGM graphics cache |
Layers-Restricted |
Project |
Display viewport out-of-date border |
Layers-Restricted |
Project |
Save site model cache |
Layers-Restricted |
Project |
Use layer colors |
Layers-Restricted |
Project |
Ignore layers with different scale |
Layers-Restricted |
Project |
Show only layers belonging to stories |
Layers-Restricted |
Project |
Center view on activated layer |
Layers-Restricted |
Project |
Mesh smoothing with crease angle |
Layers-Restricted |
Project |
Use automatic drawing coordination |
Project |
Project |
Yes, always |
Adjust flipped text |
Layers-Restricted |
Project |
Cropped perspective |
Layers-Restricted |
Project |
Drop shadows |
Layers-Restricted |
Project |
Dimensions (Document Preferences) |
Associate dimensions |
Layers-Restricted |
Project |
Auto associate |
Layers-Restricted |
Project |
Create dimensions in class |
Layers-Restricted |
Project |
Dimension standard |
Read Only |
Project |
No |
Dimension slash thickness |
Layers-Restricted |
Project |
Resolution (Document Preferences) |
Rotated Text Display |
Layers-Restricted |
Project |
Bitmap Display |
Layers-Restricted |
Project |
Design layer raster rendering |
Layers-Restricted |
Project |
Legacy 2D (Document Preferences) |
Enable legacy 2D features |
Project |
Project |
Yes, always |
Plane mode |
Layers-Restricted |
Project |
Unified view setting |
Layers-Restricted |
Project |
Plan Shadows (Document Preferences) |
Layers-Restricted |
Project |
Units settings |
Layers-Restricted |
Project |
Georeferencing settings |
Project |
Project |
Yes, always |
Page Setup settings |
Layers-Restricted |
Project |
Print settings |
All users |
Project |
No |
Reference settings (Settings button on the Organization dialog box) |
Check for out of date references |
Layers-Restricted |
Project |
Use reference priority when updating resources |
Project |
Project |
Yes, always |
Allow in-place editing of referenced resources |
Project |
Project |
Yes, always |
Manual update option |
Layers-Restricted |
Project |
Referencing method |
Project |
Project |
Yes, always |
Default class and layer tags (Class Tags List and Layer Tags List buttons on the Organization dialog box) |
Project |
Project |
Yes, always |
Database settings |
Project |
Project |
Yes, always |
User Origin setting |
Project |
Project |
Yes, always |
Page Origin setting (Move Page tool) |
Layers-Restricted |
Project |
Attributes settings (Attributes palette) |
Read Only |
Project |
No |
Resolution of exported image (Export Image File command) |
Layers-Restricted |
Project |
“Refresh updates working file” describes what happens in the working file when you use the Refresh command:
No: A refresh never updates the setting in the working file.
Yes, always: A refresh always updates the setting in the working file with the setting from the project file.
Yes, if not modified: A refresh updates the setting in the working file only if you did not change it. Once you change the setting in your working file, a refresh will not override it. To reload all settings from the project file, click Reset Document Preferences in the Project Sharing dialog box.
