Permission levels for view-related settings
Setting or preference |
Permission to modify |
Permission to commit |
Refresh updates working file |
Zoom setting |
Read Only |
Project |
No |
Class Options setting |
Read Only |
Project |
No |
Layer Options setting |
Read Only |
Project |
No |
View setting |
Read Only |
Project |
No |
Projection setting |
Read Only |
Project |
No |
Rendering option settings: Wireframe Options Shaded Options Custom Renderworks Options Artistic Renderworks Options Line Render Options Sketch Options |
Read Only |
Project |
No |
Multiple View Panes settings |
Read Only |
Project |
No |
Lighting Options |
Read Only |
Project |
No |
SmartCursor/snapping settings |
Read Only |
Project |
No |
Active class |
Read Only |
Project |
No |
Active layer |
Read Only |
Project |
No |
Document window size |
Read Only |
Project |
No |
Visibilities of layers and classes |
Read Only |
Project |
No |
Active filter for the following class and layer lists: View bar class and layer lists Classes, Design Layers, and Sheet Layers panes of the Organization dialog box Classes, Design Layers, and Sheet Layers tabs of the Navigation palette |
Read Only |
Project |
No |
“Refresh updates working file” describes what happens in the working file when you use the Refresh command:
No: A refresh never updates the setting in the working file.
Yes, always: A refresh always updates the setting in the working file with the setting from the project file.
Yes, if not modified: A refresh updates the setting in the working file only if you did not change it. Once you change the setting in your working file, a refresh will not override it. To reload all settings from the project file, click Reset Document Preferences in the Project Sharing dialog box.
