Refreshing the working file
Command |
Path |
View bar |
Refresh |
File |
When you’re editing a shared project, your working file becomes outdated when another user commits changes to the project file. Refresh the working file to get the latest changes from the project file.
To refresh a working file:
The Refresh button displays a yellow exclamation mark when the working file is out of date. Additionally, the Project Sharing dialog box has a column that indicates when a layer is out of date. To update the working file, select the command or click the View bar button.
For efficiency, only the out-of-date parts of the working file are updated. If there is a conflict between an entity (resource or class) in the working file and an entity in the project file, you are prompted to resolve the issue before the refresh can continue. Either rename or replace the entity in the working file.
