Editing sketch styles
Command |
Path |
Shortcut |
Sketch Options |
View > Rendering |
Ctrl+Shift+Alt+S (Windows) Cmd+Shift+Option+S (Mac) |
Edit the settings for the pre-defined sketch styles as needed. To create a custom sketch style, enter a unique name.
Sketch styles do not display in the Resource Manager until a sketch-related option is selected the first time.
To edit a sketch style:
Select the command.
The Sketch Options dialog box opens.
Select a style and click Edit.
The Sketch Style Editor dialog box opens. The preview graphic provides help with editing.
Parameter |
Description |
Name |
If you edit a pre-defined style and change the name, a new style is created. The name must be unique within this file. |
Edge Settings |
Wobble |
Controls how much the sketched lines are offset from the true lines of an object; drag the slider to the right to increase the wobble |
Stroke |
Controls the length of the sketch drawing strokes; a longer stroke distance increases the number of wobble points. Drag the slider to the right to increase the number of wobble points. |
Randomness |
Controls the amount of wobble and stroke variation |
End Point Settings |
Overstrike |
Extends sketched lines past their endpoints; drag the slider to the right to increase the overstrike distance |
Understrike |
Shortens sketched lines before their endpoints; drag the slider to the right to increase the understrike distance |
Randomness |
Controls the amount of overstrike and understrike variation |
Alternatively, from the Resource Manager, right-click on the resource, and select Edit from the context menu. Sketch styles can also be deleted and/or replaced from the Resource Manager (see Eliminación o reemplazo de recursos).
