Searching for a resource
The Resource Manager has a search box to help you quickly locate a resource using keywords.
To locate and use a resource:
From the Resource Manager tool bar, click the disclosure arrow to the left of the search box and select your search options.
Click to show/hide the options.Click to show/hide the options.
Search option |
Description |
Everywhere |
Search for the resource in all available libraries |
Visible File Groups Only |
Search for the resource only in the libraries that are currently displayed in the file browser pane |
Selected File Only |
Search for the resource in the file currently selected in the file browser pane |
Include Records |
Include records attached to resources in the search |
Exact Word or Phrase |
Matches only occurrences of the exact search string, not resources that contain all the words |
Enter a search string and optionally one or more basic Boolean search operators in the search box and press Enter to execute the search. The search locates the string in resource names, tags, and (if Include Records is selected in the search options) records attached to resources.
Vectorworks recognizes Boolean search operators “” (quotation marks), * (search for strings that begin with the characters indicated), AND, NOT, and OR. Boolean operators can be combined, such as combining two strings inside quotation marks with the word OR, to create precise searches.
The search operators AND, NOT, and OR are case sensitive; they must be entered in all capital letters to function correctly.
The search box retains and displays the last 10 searches; to clear this list, scroll to the bottom of the list and click Clear Recent Searches.
Ejemplo de búsqueda |
Resultados posibles |
silla verde (sin comillas) o silla AND verde |
Recursos con las palabras verde y silla en cualquier parte en el nombre de recurso, etiquetas y, opcionalmente registro; Y es el operador predeterminado silla verde silla con franjas verdes rayado verde con la palabra silla en la etiqueta |
“silla verde” (con comillas) |
Recursos con la palabra silla seguida inmediatamente por la palabra verde (la cadena de texto exacta dentro de las comillas) silla verde |
s* verde |
Recursos con la palabra verde y cualquier palabra que comienza con la letra s silla verde silla con franjas verdes sofá verde sanitario con verde en la etiqueta |
“verde s”* |
Recursos con la palabra verde seguida inmediatamente por una palabra que comienza con la letra s verde silla |
“verde s*” |
Recursos con la palabra verde seguida inmediatamente por la letra s y un asterisco (la cadena de texto exacta dentro de las comillas); un asterisco dentro de las comillas no es un operador de búsqueda verde s* |
cam o cam* |
Recursos con cualquier palabra que comienza con las letras cam; para una búsqueda de una sola palabra, se agrega automáticamente un operador de asterisco al final de la cadena de búsqueda cámara camelia campo |
*cam o *cam* |
Recursos con cualquier palabra que tenga las letras agrupadas cam en cualquier lugar; para una búsqueda de una sola palabra, se agrega automáticamente un operador de asterisco al final de la cadena de búsqueda cámara Varicam escama |
“silla verde” AND mesa |
Recursos con la palabra silla seguida inmediatamente por la palabra verde (la cadena de texto exacta dentro de las comillas) y la palabra mesa silla verde con mesa en la etiqueta símbolo de combinación de nombre “silla verde y mesa lateral” |
verde NOT silla |
Recursos con la palabra verde pero no silla sofá verde auto verde |
verde OR silla |
Recursos con la palabra verde o silla silla verde sofá verde silla roja |
Resources that match the search display in the resource viewer pane. Standard context menu commands are available for the resources, or you can drag the resource to another file if desired. Two additional features are available for search results:
Hold the cursor over a resource to display a tooltip that shows the resource’s name and location.
Right-click on a resource, and select Select Resource Location from the context menu to select the file that contains the resource in the file browser pane.
