Line into segments
| Command | Path |
| Line into Segments | Modify > Drafting Aids |
The Line into Segments command converts a selected line into the indicated number of equal length segments. The original line can be converted, or an identical line placed on top of the original and converted.
To convert a line into segments:
Select the line to be converted.
Select the command.
The Line into Segments dialog box opens.
| Parameter | Description |
| Place loci | Places loci at the segment divisions |
| Break Line Into Segments | Creates segments from the original line, converting it; deselect to place loci only |
| Leave Original Line Intact | Retains the original line, and creates segments from a copy of the line |
| Number of Segments | Specifies the number of segments to create |
Set the parameters and draw either a new segmented line or convert the selected one.
