Modifying spaces with non-horizontal ceilings and floors
When created, spaces in Vectorworks are assumed to have horizontal top and bottom edges. However, often spaces must have non-parallel or stepped top and bottom faces. Additionally, many localities have different rules about how much a space’s reported floor area must be reduced in areas with low ceilings.
To handle these requirements, the following features are available:
For 3D spaces, use the commands Fit Top of Space to Objects and Fit Bottom of Space to Objects to fit spaces to defined geometry, and to calculate volume and area accurately. See below for details.
For 2D spaces, use the command Add Area Modifier to Space to manually add modifiers and specify how much to reduce the calculated area. See below for details.
Fitting 3D spaces to defined geometry
Command |
Workspace: Path |
Fit Top of Space to Objects Fit Bottom of Space to Objects |
Architect: AEC > Space Planning Landmark and Spotlight: Add command to workspace (see Personalización de los espacios de trabajo) Context menu |
3D spaces are created with horizontal top and bottom edges, but often spaces must have non-parallel or stepped top and bottom faces. After creation, use these commands to automatically extend spaces upward or downward to fit to defining geometry such as the site model, roofs, floors, or NURBS surfaces, or to a fixed height value. This displays the space object appropriately in 3D, and also calculates the correct volume and area information.
The procedures for the Fit Top of Space to Objects and Fit Bottom of Space to Objects commands are very similar, so they are both described here.
To fit spaces to defined geometry:
Select the space object to be fitted. To clip the space with specific 3D objects that intersect the space, also select those objects.
Select the command. The Fit Top of Space to Objects or Fit Bottom of Space to Objects dialog box opens.
Parameter |
Description |
Net boundary matches gross |
Uses the same boundary for both the net and gross definitions. When selected, the net settings are unavailable. |
Gross / Net |
Alters the gross or net boundary of the space object. The same settings are available for both boundaries. |
Top/Bottom bound defined by |
Select an option to define the top or bottom boundary of the space: Fixed height only: Sets a maximum height for the space boundary according to the Top/Bottom bound and Top/Bottom offset settings Constraining objects only: Clips the space boundary with 3D objects that intersect with the space Fixed height plus constraining objects: Sets a maximum height for the space boundary and also clips the space with 3D objects that intersect with the space |
Top/Bottom bound |
If a “fixed height” boundary option is selected, select the top or bottom boundary object for the space |
Top/Bottom offset |
If a “fixed height” boundary option is selected, enter a distance to offset the space from the boundary object |
Constrain top/bottom of space object to |
If a “constraining objects” boundary option is selected, clips the space object with roofs, floors, slabs, 3D polygons, extrusions, or NURBS surfaces. All objects on layer: Includes all 3D objects on the selected layer that intersect the space as clipping objects Selected objects: Includes only selected 3D objects that intersect the space as clipping objects |
Use for roof/slab |
If a “constraining objects” boundary option is selected, select which portion of roof or slab objects to use as the boundary |
Modifying the area of 2D spaces
Command |
Path |
Add Area Modifier to Space |
Context menu |
For 2D spaces with low ceilings, manually add one or more enclosed 2D primitive objects (for example, a rectangle or polyline) as modifiers to specify how much to reduce the calculated area.
To modify the area of a 2D space:
Place one or more 2D objects to use as a modifier on the space object. Only the part of the modifier that overlaps the space object is subtracted from the space area. If modifiers overlap each other, both modifiers are fully subtracted from the space area.
Select both the space object and the modifier.
Select the command.
The Add Area Modifier to Space dialog box opens.
From the Subtract from Space list, select the percentage of the modifier’s area to subtract from the space’s area, or select Subtraction Custom and enter a custom Subtract value.
See Changing space modifiers for details about editing the modifier.
