 Object/hidden object display and pen attributes in section viewports
  Override the viewport settings and set the display and pen attributes of specific 3D objects in a section viewport, either for all objects in a class, or for individual objects.
To set the object display and pen attributes:
Do one of the following:
Click Edit in the Object/Hidden Object Display by Class dialog box (see Presentación de objetos tridimensionales según clase en encuadres de sección )
Click Object/Hidden Object Pen Attributes in the Cut Plane and Display dialog box for one or more selected eligible objects; see Presentación de objetos tridimensionales en encuadres de sección
The Object/Hidden Object Display dialog box opens.
| Parameter | Description |
| Class Name | When the dialog box is accessed from the Object/Hidden Object Display by Class dialog box, displays the name of a single class being edited, or is empty if multiple classes are selected |
| Object/Hidden Object Display | When the dialog box is accessed from the Object/Hidden Object Display by Class dialog box, select the display settings for the objects/hidden objects in the class |
| Hidden Line/Dashed Hidden Line Pen Attributes | Sets the attributes of the visible edges of objects. Select whether to use the object/viewport pen style, color, and/or thickness, and then select the Atributos de pluma as needed |
